Random Objects in Instancing
   7757   14   0
Hi.
I'm using a object merge and copy node to instance geometry to particles. This gives me many objects but all the same.
How would I go about setting it up to randomly instance a group or number of different objects ? So, as the particles emit, it randomly assigns a different geometry to that particle.
Eugene
Well you could use a switch SOP and stamp function in a copy sop.
floor( rand($ID) * opninputs(“../switch5”) )
The switch value , is the number of inputs you have in this case 5
r
Edited by - Sept. 30, 2009 15:42:56
Gone fishing
great, thanks… i'll give that a go.
Eugene
Hi.
I did that, but the expression didn't seem to work. I plugged in 2 object merges but nothing appeared when I played the sim.
Any thoughts ?
Thanks.
it really helps if you post a scene file …….
r
Gone fishing
ok, sure … here it is… sorry for the newbie approach to my scene !
Eugene
instance_test.hip (856.4 KB)
if anything I confused you with my previous answer. Its always good to post a scene file !
r
instance_test_fixed.hip (997.2 KB)
Gone fishing
great, thanks for your help…
eugene
Hi… i spoke slightly too soon !
I have a new issue, where big geometry of the instances is appearing at the end locator.
I just want the objects to swirl in a nice vortex, but at the moment, they're hidden by this new appearance of geometry. This scene will show you exactly what I mean.
Eugene
instance_test_Newissue.hip (335.4 KB)
I am struggling to make sense of just what you are trying to do. You have two orbit nodes after each other ? Yet none of your particles are actually rotating round a centre point.
The way to solve problems is to break the problem down into small chunks. That way its easier for you to communicate just what your are trying to achieve.Take a look at the example files for each POP node , then make yourself a small test to devlop that part of a solution to a bigger problem.
r
Edited by - Oct. 1, 2009 22:02:05
Gone fishing
Sorry,
I have developed the effect I want the particles to move in (whether the nodes are wrong or right, I'm not sure) but I have an issue with some odd geometry displaying itself at the end section of my particle stream.
Eugene
Hi.
Perhaps this scene will make my issue a little clearer.
Any help would be appreciated.
Eugene
instance_test_newissue_207.hip (333.3 KB)
hey folks,
sry to bump into this thread, but i have a similar problem ))
i followed the “Creep Tool With Copy Stamping” Tutorial of the sidefx website. I created those different colored pebbles and put them in a partion SOP to create a different group of each pebble (rock_$PR).
Now i want to assign these pebbles to a new template. Say i have a grid with 9 points in it so i would need exactly 9 of those pebbles. Obviously i have to use the copy SOP but i can't solve the problem with the switch SOP method because all my primitves are in ONE node.
Can anyboy help me please?? )
best regards,
Manu
ps. sry Eugenerockstar for interfering
http://vimeo.com/user2522760 [vimeo.com]
http://stormbornvfx.com/ [stormbornvfx.com]
Manuel Tausch
hi everyone!
i found the solution to the problem, the copysop can't handle primitive points so ein used the $PT variable and and a rand() expression to stamp the primitives into my copy SOP.
Now i am really confused because the copy SOP distributes the primitives randomly in space, they're not sticking to the provided template points.
I used a transform SOP to center the pivot of each primitve ($CEX,$CEY,$CEZ) but that doesn't work.
I would really appreciate some help, please take a look at the hipfile!
thanks a lot, greetings,
Manu
creep and stamping.hipnc (68.4 KB)
Manuel Tausch
ok guys!
then i will provide the answer myself
if your center ist say at 5,5,5 you can zero it by writing the following simple expression:
$TX - $CEX , $TY - $CEY , $TZ - $CEZ
in the position value of a transform SOP !
maybe it helps someone,
cheers
Manuel Tausch
