I want to install the Ocean tool kit, but i don't understand how to install it, i feel so f*cking stupid.
http://anusf.anu.edu.au/~drw900/houdini/ocean/docs/ [anusf.anu.edu.au]
i'm trying to install from binary version.. don't get it, what's .bashrc and .cshrc and how to i change the houdini path in those files?
cheers and thx!
.bashrc and .cshrc hot install
13583 16 0- klasse
- 60 posts
- edward
- 7899 posts
- klasse
- 60 posts
- edward
- 7899 posts
- klasse
- 60 posts
- Alanw
- 320 posts
OSX has a terminal app located in your Utilities folder. If you open it and go to it's preferences you should be able to set which type of shell it's using. I would set it to use bash.
Now go to your home directory and find a file named .bashrc. If it doesn't exist yet then you can create it with a plain text editor. This file is used to define environment variables, setup the shell preferences and define aliases among other things.
One problem is OSX doesn't display hidden files in the Finder by default so you're going to have to google for ways to make them show up. (any file with a period in front of it's name “ie .bashrc” is hidden by default)
The next problem you may encounter is figuring out what your path needs to be in the environment variable you're setting up. I usually use the terminal to “cd” into whatever folder I need the path for and use the “pwd” command to print the path.
- klasse
- 60 posts
Alan, really thank you for that, i now understands more of what's going one!
Although i'm still having problems! I've tried to ad a file in my home dir named .bachrc
then i when to the terminal (the terminal is set to bash) typed env to make sure it got added. nut nothing….
then i tried to add the path to .bash_profile and now i can see the houdini path in the terminal when i type env…
but still, it's not working, HOT isn't getting imported.
please, thanks!
please, thanks!
- klasse
- 60 posts
- Alanw
- 320 posts
klasse
this is what i'm putting in the files:
export HOUDINI_PATH=“/_Lib/Houdini/hotbin_osx_H10.0.401_1.0rc8;&”
I've never installed HOT on a Mac so I'm honestly not sure. It sounds like you're close though.
You should be able to echo the variable from a Houdini text port as well. echo $HOUDINI_PATH
Is there a Houdini.env file provided on the Mac? If there is you may want to try defining the variable there instead.
- klasse
- 60 posts
- edward
- 7899 posts
- klasse
- 60 posts
- Alanw
- 320 posts
Try this in your .bashrc and make sure you completely shut down your terminal between testing changes.
HOUDINI_PATH=/_Lib/Houdini/hotbin_osx_H10.0.401_1.0rc8;&
Are you using Houdini 10.0.0401?
Also, to confirm if your changes are taking place I'd make sure you're using echo from the hscript textport inside Houdini. (and you will need to restart Houdini after every change made to the variable)
- klasse
- 60 posts
Alanw
if i put that in the .bashrc nothing happens.
if i put it in the .bash_profile file i geet a syntax error:
syntax error near unexpected token `&'
- klasse
- 60 posts
if i do this:
export HOUDINI_PATH=“/_Library/Houdini/hotbin_osx_H10.0.401_1.0rc8;&”
in the .bash_profile file.
then go to applications and running the “Houdini Shell.terminal” and then runing the command:
hconfig -ap
now i can see my houdini path in that long list.
but i don't see anything when i'm opening up a hscript texport from inside houdini and running “echo $HOUDINI_PATH”
can there be a bug? i'm running 10.0.422
hconfig -ap
- Alanw
- 320 posts
klasse
if i do this:
hconfig -ap
I don't think there's a bug. If hconfig finds your variable then it sounds good to me.
The HOT documentation states that you must use the same version of Houdini that the pre-compiled binary was compiled with, which looks like 10.0.401. This is most likely your problem. It looks like the .401 build is still available as well, so I'd try that. Or, if you're feeling brave try compiling HOT from source.
- klasse
- 60 posts
