The HOUDINI_DSO_PATH env variable on Windows
   3162   0   1
Hi there folks,
Can someone explain what I'm doing wrong with setting the HOUDINI_DSO_PATH variable on Windows (WIN2k & XP-Pro)?
It works well on IRIX and Linux but on Windows, I can never get Houdini to find custom DLL's in locations other than $HFS/houdini/dso/ & $HOME/houdini/dso/
On UNIX I set it to some like (hconfig says):
HOUDINI_DSO_PATH := ‘/usr/hfs/houdini/dsousr/people/mstory/houdini/dsousr/people/mstory/projects/houdini/dso:./houdini/dso’
Works great.
And on Windows I set something like:
HOUDINI_DSO_PATH := ‘C:\PROGRA~\SIDEEF~1\HOUDIN~1.383/houdini/dso;C:\DOCUME~1\mstory\MYDOCU~1\houdini\dso;C:\DOCUME~1\mstory\MYDOCU~1/proj\test\houdini\dso’
Doesn't work at all … that is, it will find the DLL's in $HFS/houdini/dso/, but nowhere else …
Clues? Hints?
–Mark
You are no age between space
