Stupid copyGroup problem
   4444   5   1
Hi, I've got a really stupid problem with copyGroups from the copySOP, or just any other bunch of groups. I just can't figure out, how to get the primitives in to one group again. I need that for exporting.
I could use some help!
IMHO
Lorenz
hi there,
have you seen the checkbox “Create Output Groups” within the CopySop?
regards,
Manuel
http://vimeo.com/user2522760 [vimeo.com]
http://stormbornvfx.com/ [stormbornvfx.com]
Manuel Tausch
That's the function I turned on because I make transformations with the groups. But now when I export with the ROP-Drive into one .obj I got every group as one object in the other software.
IMHO
Lorenz
You can just delete all the groups before your ROP output driver by putting down a group sop, toggle Enable off, then in the Edit->Delete tab put * to remove all the groups. If you still want just 1 group with everything in it, don't toggle off the Enable toggle, give it a name, then in the delete parm put * ^mygroupname
try setting the outputgroup of the primitives to something like this:
mygroup_$NCY
that puts all your copied primitives into one group.
( $NCY = Number of copies, $CY=current copy )
Manuel Tausch
Thank you very much Graham! Overlooked the edit-tab; I was stuck with the combine tab. Asnowcappedromance, thank you also for answering in a blink.
A lot of work is still ahead… 8)
IMHO
Lorenz
