adding "mount points" for props to a procedual pol
13060 16 1- elderic
- 24 posts
Hi there,
I'm quite new to houdini… so please bear my stupid questions
I have an poly object which I model procedurally.
Let's say it's the base of a house.
Now I want to be able to add “props” in random amounts to it… but in certain locations. A good example would be various chimney-types or antenna's and satellite dishes, doors, windows, etc.
I need a sort of “mount point” for those that I want to keep on the geometry in certain specified locations. These should not change even if I subdivide the faces, polyextrude them, etc. They just move with the new geometry then in orientation and location.
Trying face-numbers sucks kinda. My other idea was getting the bounding-box Y-max to place stuff on top… but that doesn't fix the other location issues.
Can I somehow assign a point/vector/handle/whatever onto a face x, which stays there when the modelling process continues?
ideally with a transform-node or something?
greetz,
-elderic
greetz,
-elderic
- edward
- 7899 posts
- elderic
- 24 posts
edward
Does using the Group SOP work (make sure you create a “primitive” group)? In most places where you use face (aka primitive) numbers, you can use this named group instead.
actually I would have to try that
another idea I stumbled upon would be a rivet… this toll already seems to do what I want, the problem is: it operates on the wrong level (same level as geometry-node). I will try some stuff (including your suggestion and read some more docs. perhaps I come up with a solution.
my final goal is a fully procedual house with multiple random props… for assembling of a random procedual “city”.
well… back to the drawing board.
- edward
- 7899 posts
- elderic
- 24 posts
ok, let's just forget my (imagined) problem that face idicies are inherently bad. they seem to work fine
the attached scene implements my basic idea.
now I have the next problem.
I use a single “scatter”-point to attach a point to face X, but it's randomly distributed across the polygon.
is there a node to modify it easily to place the point directly in the face-center or something?
EDIT: the node in question for this would be “singleGridOnPrimitive” in my test scene
- edward
- 7899 posts
- elderic
- 24 posts
Alrighty.
Seems to work. Two questions now:
1. How do I localize the position of the node in the prim()-function?
I want to get rid of the absolute path “/obj/box_object1/box1” to something more local like “./box1” (which doesn't work)
2. how do I orient the box to the face normal at that position?
my approach would be to get the normal and extract rotation informations for the box-object. what are the hscript-func's for that?
btw: thankx a lot for your suggestions up to this point
-elderic
-elderic
- edward
- 7899 posts
elderic
It doesn't work because “.” means the current node. You probably want to go UP a level first like, “../box1” if it's a node at the same level. You might need more “../” in front if it at a different level, etc.
- edward
- 7899 posts
- elderic
- 24 posts
- asnowcappedromance
- 512 posts
- Anonymous
- 678 posts
- 512 posts
- sanostol
- 577 posts
hi manuel,
if You use N to orient Your copies, they are only restricted to one axis, but they still have the freedom to rotate 360 degrees around this axis. not defining a upvector is unsafe. by adding a upvector You get them locked to a specific orientation. iksystems also use a upvector, for example
Martin
Martin
- 512 posts
- pelos
- 621 posts
i am trying to understand the opinputpath expression that you use,
you put it on the prim () to get the polygon, but
why you use
prim(opinputpath(“.”,0),5,“N”,0)
prim(opinputpath(“.”,0),5,“N”,1)
prim(opinputpath(“.”,0),5,“N”,2)
why you set those numbers in that particular order?
i am assuming the 5 is the # of the polygon. N for the Normal and the 0 1 and 2?
if i want to set a point in the middle of several primitives? (Polygons) i can change the “5” for the name of that group right?
thanks .
why you use
thanks .
- old_school
- 2540 posts
