Error:- SQLite is too old and the application cannot run.
   19631   9   1
Hello
I have installed Houdini Apprentice…
When im opening my app im getting error…
Error:-
The application has been updated, but your version of SQLite is too old and the application cannot run
I have installed SQLite3 in my machine…
OS- Ubuntu 9.10
Arch- amd_64
application open with the above error but no icons on the self….
What should i do to over come this error…..
-prabu
Same here.. installed everything depending SQLite
same here, after my ubuntu 9.1 update
houdini is not working …
anyone has a solution please …
Hmm … I'd try a fresh new install of Houdini. Say, like one the daily builds.
prabu
Hello
Error:-
This appears to be related to the help browser. Try unchecking the “Edit -> Open Help Browser at Startup” menu item.
hello derrick,
I did what u told but that didn't help…
solution doesn't make any sense… i told thrz no icon in the self but application opens by showing the error as i mentioned earlier….
How do you say by uncheckin the “Edit -> Open Help Browser at Startup” menu item. will help in this case….
prabu
hello derrick,
The missing icons and the error message appear to be separate issues. Unchecking “Edit -> Open Help Browser at Startup” should avoid the the error message about SQLite. This is a step in the right direction but not a solution to all of the issues you described.
Thankz derrick,
Hello Houdini people what should i do to make houdini apprentice to work properly on ubuntu 9.10
I am not able to find any icons on the shelf…
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=17069 [sidefx.com]
Thankz Edward,
My problem solved after following your instructions
