Creating a Simple Screw
   50066   22   2
Hi all i was wondering if anyone had a good way to model a screw as im beat.
This is what i have done so far:
http://i23.photobucket.com/albums/b395/1davidlyon/Screw.jpg [i23.photobucket.com]
I have used a curve and snapped the points to the grid then used a revolve to get a 360 model.
I am wondering if there is a HELIX shape or option in houdini like 3ds max has ? If someone knows how to create a simple spring that would do.
This is the kinda method i used in 3ds max:
http://www.freeitsolutions.com/3ds/viewTutorial.aspx?id=3380 [freeitsolutions.com]
Lyonz
Try this. It's very simple though.
helix.hip (43.6 KB)
Thats perfect wondering how you done this ? what the expressions mean in the divisions, arc angles and position parameters, to get this to work.
Try searching on odforce.net … I vaguely recall someone putting up an example.
edward
Ive had a look on odforce and couldnt find an example would someone be able to break down how the file above was created ? as i get errors when reconstructing it …
The error i get is bad parameter reference “../turns” in parameter /object / circle_object2/circle1/divs
The error i get is bad parameter reference “../quality” in parameter /object / circle_object2/circle1/divs
You can add a lineSOP, then add a pointSOP. Inside the pointSOP's position parameters type this in the x field…
sin($PT * 30) * 0.5
and this in the z field
cos($PT * 30) * 0.5
This will give you a helix. Then continue modeling. Or drop down a vopsop and look at the trigonometricVOP.
Here have a look. This is a quick mockup, so its not polished in any way.
screw_02.hipnc (91.8 KB)
Yea just started looking at expressions and in the Help file it talks about creating a spiral using SIN & COS. This is all i need thanks
Hi Guys,
Another great trick…
Try using the twist SOP on a highly subdivided box.
Maybe not the most elegant, but damn, if it doesn't look like a screw to me!
cheers,
-j
jacob clark
Hi Guys,
cheers,
-j
Yea i tried this at first and gets you a great result if your after a ground drill like this.
http://www.tradevv.com/TradevvImage/productimages/Ground-drill-A5ba18.jpg [tradevv.com]
ok here's my attempt at a screw. Lag bolt more like it. I like the profile approach as opposed to the old school make-a-corkscrew-then-pound-the-crap-out-of-it way.
Hopefully the cookie (boolean) operations hold up…
I am sure that there are procedural ways to better fuse up the shaft to the thread and better work on the tip. It's just lining up your ducks.
As well I eyeballed the copy SOP to align the sweep of the profiles but I am sure you can get simple math in there to do real thread pitch standards.
screw_jw.hip (83.7 KB)
This is what I came up. It's not ready yet, many parameters are missing or need to be rewired but it's a good start. Not faraway from full working procedural.
Below you can find HIP file and OTL for DOWNLOAD:
http://www.4shared.com/file/149824982/e2bb698b/screw.html [4shared.com]
http://www.4shared.com/file/149826584/a8cbfd51/Screw_OTL.html [4shared.com]
Looking good.
When you are satisfied upload it to the exchange.
You can download the “Bolt asset” from houdini exchange.
Its basically just a boolean between a polywired helix and a tube.
This is my first go at making a screw, i have tried a few ways but seem to get errors when rendering does anyone know what is causing the problem ?
screw_problem_109.hip (2.6 MB)
Look closely how your polysplit2 and polysplit3 are layed. You created broken geometry and from those nodes down all geo is more and more broken each time you add something. Fix this and all errors in network belowand you should see improvment.
Edited by - Jan. 23, 2010 17:40:04
Even when it is a simple tube at fuse 1 near the top i get errors like the edges are facing the wrong way ?
When i try to polyextrude a simple line i get problems.
1. Use Global extrude Y value not Local, so you don't have to compensate movement on other axis like you done in your geo.
2. Turn off output front on OptionsTAB of polyextrude1. When you extrude line it leaves it as a front face
Thanks that fixed it.
I know the question was: How to model a screw :-)
But hopefully this is helpy, too. If it's not necessary to have the real geometry, maybe a simple displacement shader can do the work.
This solution gives more flexibility and can bring a cleaner look without having “big” models. If you get “artefacts” in the rendering, make sure “Predicng” is set in the SOPs render settings.
