Mantra issue (mantra: Error writing data to image device)
   8846   5   2
I'm unable to render, though MPlay window opens (black screen no image). I'm using Houdini HD version 10.0.463 on a Windows 32bit vista setup The error shown in the console is:
UT_NetPacket::write: No error
So far I've checked that hmaster & Mplay are excluded from Window firewall
deleted “houdini10.0” (config) a couple of times and restarted Houdini
Reinstalled Houdini twice.
I've seen this issue in a search but not a clear fix
anyone?
update:
Tech support have come back to me (best tech support in the 3d industry ) and believe it to be:
“ A communication problem. Houdini is not opening the packet it is supposed to, to send info to mplay.”
from some initial tests.
I'm currently getting the same error:
using win 7 64 bit Houdini Version - 10.0.554
IMG_TileWrite::socketWrite: No such file or directory
any ideas?
it could be related to a firewall settings or an anti-virus software:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=18687 [sidefx.com]
I have the same problem… Does anybody know why that happens?
I got the same issue all the time, very annoying when you want to render over night, did anyone ever find a solution to this?
try running houdini as an administrator
Albert
