Did I make a mistake?
I got very excited about the latest Ubuntu release 9.10 and installed it on my Macbook Pro ( dual boot. ). I downloaded and installed houdini apprentice for Ubuntu 9.04. Am I correct in realizing that this won't work? The intall went ok, and I can source the proper setup file. I just can't launch the binary executable.
whoops,
jonah
p.s. how long until we get an install for Ubuntu 9.10?
Houdini in Ubuntu 9.10 ?
7690 12 2- freejonah
- 37 posts
- silvina
- 181 posts
Please check this thread:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=17445 [sidefx.com]
- evanschaible
- 3 posts
freejonah
whoops,
jonah
I run Houdini on Red Hat Fedora 12 and everything works perfectly. I think you may find you need to create certain environment variables (the purpose of ‘source houdini_setup’) and than create a shell script that does this automatically for you.
Im not too familiar with Ubuntu but Im pretty sure the process is the same, if not similar.
Create a new shell script and use this code:
#!/bin/bash
cd <insert your install file path here>
source houdini_setup_bash
houdini
What this does is auto sources your file and than launches the program. From the way I understood your post this is the answer to your problem, I think…
- Evan
Red Hat Fedora 12 | Intel Core2Quad | Geforce 9600GT 2GB VRAM | 4GB RAM
Freelance FX Technical Director | www.ParticleFlow.net
- edward
- 7899 posts
- oldiesgoodies
- 20 posts
Hi
]I just installed Houdini(Apprentice 32) on Ubuntu. Everything works fine except that the screen update is very chokky-laggy when I try to rotate my scene with space+left mouse. It feels like the navigation just does not want to work.
When I press Esc and rotate my scene with mouse, it is just fine. I really have no idea what might cause such weird issue.]
I am using it on macbook pro
Any ideas?
thanks
Any ideas?
thanks
- edward
- 7899 posts
- oldiesgoodies
- 20 posts
- edward
- 7899 posts
- oldiesgoodies
- 20 posts
- oldiesgoodies
- 20 posts
- edward
- 7899 posts
That's good to know. I've taken the liberty to start a community wiki page for incompatible software:
http://odforce.net/wiki/index.php/IncompatibleSoftware [odforce.net]
- edward
- 7899 posts
You might also want to log a bug with them to see if they might know what's going on. https://bugs.launchpad.net/ubuntu/+source/mouseemu/+bugs?field.status:list=NEW [bugs.launchpad.net]
- oldiesgoodies
- 20 posts
