incandesence in shader ?
   3699   4   0
Hi ,
how can i get incandesence in a shop mantra surface ?
I assume you mean what is called a constant shader in houdini. Look for “vex constant”.
Fabian
If you use the PBR renderer, then you can make glowing surfaces (if that is what you mean)
Jobless
Hi ,
Should i use a specific shader or tweaking with PBR ?
Use a normal shader and increase the color values (very often above 1). Then, in the pbr render settings make sure the diffuse limit is set to 1, or higher.
Jobless
