Sorry as this is a bit of a newbie question but how can take values from chops and add them to my position value of an object, not just replace them? For example if i have an object following a curve but i want it to speed up/ down according to chop values?
Using CHOPs
2929 2 0- donners13
- 6 posts
- graham
- 1922 posts
You can use the Export CHOP to send your modified animation channels back to a parameter without harm to the original data.
In the attached file I have a cone going along a curve. I use a Fetch CHOP to get the pos channel into CHOPS where I then use a Spline CHOP to modify the animation. I finally use an Export CHOP that exports the animation and overrides the original channel data with this new data.
- donners13
- 6 posts
