PyroFX question
5551 7 2- ex_pfc_wintergreen
- 11 posts
I have a model of a laptop that I want to set on fire with pyro fx. I've never used pyro before but I've watched some tutorials. I don't want the flames to be emitted from the whole laptop, just the bottom part with the keyboard and the battery. I've tried creating a group from the bottom part of the laptop but I can't figure out how to just source that group for the flames and not have the whole model be the source. Any advice? Thanks
- old_school
- 2540 posts
You can use attributes.
Easiest way to do this is from the shelf select the Fuel source tool, select your geometry you want to be the fuel (your laptop) and start painting fuel with the LMB and remove fuel with the RMB.
You can RMB in blank space in the viewport to see all the brush options for the LMB and RMB.
You can also paint temperature. Areas where you want the fuel to ignite strongly paint with LMB and those that you don't want to burn RMB.
The shelf tool creates the correct geometry attribute for you. You can use SOP methods to apply that attribute to your group.
- 11 posts
Thank you for your help. I'm still a bit confused as to how I would apply the attribute to my group and then get it to work in the pyro simulation. I've tried painting the whole thing with fuel, either with the foreground or the background color, but neither one seems to make any difference in how the fuel is emitted. I re-ran the simulation each time I changed how I painted the fuel and stopped it on frame 12. No matter what I did, it looked the same. I know I've missed a step somewhere.
Maybe these screenshots will help?
- circusmonkey
- 2624 posts
- 11 posts
- 11 posts
I've done a few tests with some spheres and boxes, and I can't get the fuel to only be emitted from a certain part. I followed the steps in the help for the Paint Fuel node, and I still can't get it to work. No matter how I paint my sphere, the fuel always looks the same when I re-simulate it. I'm getting some sort of error in the pyrosolver that could be a clue, but I can't figure out exactly what I need to change.
- circusmonkey
- 2624 posts
- FANFAN1
- 1 posts
ex_pfc_wintergreen
Thank you for your help. I you have found the answer to your problem.
Tax Refund [taxpal.ie] accounting solutions [sraccounting.ie]
