HUD -Poly count
   3671   2   1
Hello, I found several posts related to HUD but only on making sliders to help our workflow but what about poly count? Id there a way to turn on/off HUDs related to vertices, edges, faces or object count? I have to admit that I'm used to that in Modo Maya and Max.
Why not make your own slate tool. Its pretty easy all you need is a font sop to read in your attribute values. The basic expressions set of videos from sidefx cover this.
Rob
Gone fishing
circusmonkey
Rob
Thanks for your input. I didn't knew that was possible. Right now I'm following the 3Dbuzz intro to Houdini tuts. I definitely will have a look at that! Thanks again
