I am very much interested in writing some plugins in houdini using hdk.I followed the steps given in sidefx website in using the hdk.
I tried to open a program from /Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources/toolkit/samples/standalone/ from command line of my macbook.
I tried to open a program using hcustom command in standalone folder,but I couldn't since I got the following error:
-bash: hcustom: command not found
Could anyone please tell me how to include the hcustom command in .profile file on mac.Thank you.
Problem with hcustom
8196 9 4-
- chaitanyakapu
- 10 posts
- graham
- 1925 posts
You need to initialize the Houdini environment. You can either source /Library/Frameworks/Houdini.framework/Versions/version_number/Resources/houdini_setup or you can launch the terminal by running Houdini Shell.terminal in the Application directory.
- chaitanyakapu
- 10 posts
Thank you very much for your help.I am a newbie to programming in HDK.After
typing hcustom -s geoisosurface.C in the standalone folder in the terminal,I got the following error .
Making geoisosurface.o from geoisosurface.C
cc1plus: warning: command line option “-fobjc-gc-only” is valid for ObjC/ObjC++ but not for C++
/var/folders/Eo/Eo7qMOW+EP0hnNKwDNxMHk+++TI/-Tmp-//ccWnVOM3.s:unknown:FATAL:can't create output file: geoisosurface.o
Compile failed
Could anyone please help as I got no clue of what exactly is that.
Compile failed
- koen
- 793 posts
- chaitanyakapu
- 10 posts
Thankyou very much for your help Keon.I appreciate it.I copied the toolkit folder to my home directory I hope it compiled well,I got the following message after typing hcustom -s geoisosurface
Making ./geoisosurface from geoisosurface.o
g++ geoisosurface.o -o ./geoisosurface -L/Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources/dsolib -L/Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources/python/lib -Wl,-rpath,/Library/Frameworks/Houdini.framework/Versions/10.0.528/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.528/Libraries -L/Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources/Frameworks/Houdini.framework/Versions/10.0.528/Libraries -F/Library/Frameworks/Houdini.framework/Versions/10.0.528/Resources/Frameworks -framework Houdini -lpython2.5 -arch x86_64 -fobjc-gc-only -framework OpenGL -framework Cocoa -rpath,@loader_path/Libraries
then I tried to execute it by ./geoisosurface,I got the following error.
objc: ‘/Library/Frameworks/Houdini.framework/Versions/10.0.528/Libraries/libHoudiniUT.dylib’ was compiled with -fobjc-gc-only, but the application does not support GC
objc: ‘/Library/Frameworks/Houdini.framework/Versions/10.0.528/Libraries/libHoudiniUI.dylib’ was compiled with -fobjc-gc-only, but the application does not support GC
objc: ‘/Library/Frameworks/Houdini.framework/Versions/10.0.528/Libraries/libHoudiniAPPS2.dylib’ was compiled with -fobjc-gc-only, but the application does not support GC
objc: *** GC capability of application and some libraries did not match
Illegal instruction
Please help me with this.
Illegal instruction
- aswaab
- 216 posts
I'm trying the same thing on my mac. I figured out the first issue was write permissions.
Getting these same errors trying to use the generated geoisosurface file.
Illegal instruction
I'd like to see this answered, as well.
Illegal instruction
- larsvdb
- 19 posts
- aswaab
- 216 posts
- jtnimoy
- 1 posts
- aswaab
- 216 posts
