Hi
Can any one help me how i can convert MPEG to MIDI.
I have a piece of music in Mpeg format.
I'd like to bring it in to Houdini so that i can drive my animation with that music. In order to do that I believe i have to convert it to MIDI file to import it to Houdini. Can any one help me ?
Thanks in advance.
Steve
Need Help in CHOPs for (Converting from Mpeg to MIDI)
5650 13 3-
- aplink
- 365 posts
- LFX
- 67 posts
To get animation curves out of audio material a .wav file is doing just fine. You can use filter to get the different frequencies, but a clean midi is another thing. I notice you make a lot with audio. Why don't have a look at http://www.andrew-lowell-productions.com/andrew-lowell-productions/resources.html [andrew-lowell-productions.com] ? It's all covered there.
IMHO
Lorenz
Lorenz
- aplink
- 365 posts
- edward
- 7923 posts
- aplink
- 365 posts
- edward
- 7923 posts
- aplink
- 365 posts
- edward
- 7923 posts
- andrewlowell
- 539 posts
yeah, I think workflow wise it's important to keep a good separation between file i/o and conversion, and the artist's workflow, scenes etc.
So, there's much more efficient ways to convert all the input files outside of Houdini. First find the best solution for converting your files into .wav or image sequences, then pipe them into CHOPs 8)
Memory is an issue with CHOPs since it has to contain the entire file in memory, remember the unload feature.
As for converting a file into MIDI this will always only be an approximation, because in audio data the start of a note, exact frequency of a tone, things like that are “wishy washy” and not exact. But, probably a triggering system would be a good first step if it's absolutely necessary to convert to MIDI. If you're just looking for a peice of information from the data, like frequencies .. MIDI conversion might not be necessary.
- aplink
- 365 posts
Hello, Andrew :
Thank you very much for your help!
It's nice to hear from you. I Remember you got a new apt.
I noticed that you are in Sidney now.
That' what i am trying to do now and do not know how and what solution would be the best to convert to midi or wav.
Can you help me please.
Thanks so much again and wish you the best in Sidney.
Young
Young
- andrewlowell
- 539 posts
I don't exactly know what would be best for your needs, I was just suggesting something “outside” of Houdini. Houdini is great at fx / animation / synthesis etc, but it's not a file i/o program per say.
So, there's probably lots of hacky free programs you can use, you could also maybe use a video or sound editing program for this. Not sure what will work with your codecs etc
- aplink
- 365 posts
- andrewlowell
- 539 posts
- aplink
- 365 posts
Thanks million, Andrew.
I wonder if i can ask a favor.
Can you convert the file i posted to wav or midi format for me so that i can import it to chop ?
I can send the file if you can.
And, let me know how you'd charge.
Or, if you can do further with the the music file using chop for me that will be much better. Would you please let me know.
Young
by the way, i could manage convert a music file bought from itune to MPEG usng a program (do not remember) i got from google long ago after i bought you ebook.
Young
