Possible bug in 10.0.554 Ubuntu 64 bit
   2648   2   1
hi..
I'm on Ubuntu 9.10 64-bit running Houdini 10.0.554. I am rendering an l-system using a stamp function to fetch a variable for the angle value. The variable affects the geometry in the OpenGL view but not in the Mantra render. Probably my ignorance for missing a setting somewhere.. does anyone have any ideas?
thanks!
I installed a skylight in my apartment… the people who live above me are furious!
- Steven Wright
Make sure the “purple” circle is also around the same “blue” circle around your display node.
The angle was set using a copy stamp parameter, which is not available when point instancing is used :roll:
- Steven Wright
