folder radio buttons callback script
   7096   7   2
Hi!
Is there any method to call callback script after switching tab of a “radio button folders” in HDA?
Thank you
There is no direct way to do it, but attached is a hack that mimics it.
I have a set of radio button folders with the parm tuple name “radios” (they could be any type) and you can change them as you will. I also have an integer parm that channel references the first folder in the group “radios1”. Attached to that I have a callback that merely prints the new folder index value. When the folder changes, the parameter then changes and executes is callback script which you could do whatever you wanted then. Since it's just for calling back you should probably hide it.
fake_folder_change_callback.hipnc (38.9 KB)
woow that is great!
Thank you so much!
Could you only explain to me, why when I have script ch(“radios1”)
it changes while changing tabs? I have thought that radios1 is the first tab and it could be 0 or 1 if the tab is selected or no ?
I'm not really sure why. Trying to access folder information has always been kind of strange and unreliable. I believe trying to ch(“radios”) doesn't work because radios is actually the group of folders and you can't actually evaluate it. That's why you need to access the first folder directly. Unfortunately I don't have a much better explanation. I really hate scripting access to folders
Thank you graham
I hate it too and hope that it would be better in houdini 11
graham
It can't work because “radios” is a parameter name and ch() requires a channel name. ie. For the same reason that you need to use ch(“tx”) isntead of ch(“t”).
Thank you
And could you explain, why when I have script ch(“radios1”)
This is a bit old but I think the idea might still be usefull in specific cases. One way to achieve this goal via a workaround would be to use python code and set the folder type to radio buttons.
The idea is to set all tabs parms callback as usual (before setting them as radio buttons) aside from the root folder callback that contains a code similar to the one below:
eval(retrieve_python_callback_string_function(root_folder_callback_string, **kwargs))
As we are using the root folder callback input parm with the previous python code, we need to ensure that we provide a root_folder_callback_string that would be returned by our function when the root folder tab will be the one selected.
Then your "retrieve_python_callback_string_function" either return the root_folder_callback_string when kwargs.eval() result is 0.
if kwargs['parm'].eval() == 0:
    return root_folder_callback_string
Or returns the current selected tab callback's script string by returning the folowing commands.
else:
    parm_template_tags = kwargs['parm'].parmTemplate().tags()
    return parm_template_tags["script_callback:{}".format(kwargs['parm'].evalAsString())]
For sure you could code this function as a one line python code directly in the root folder callback input, but I found using a function for that cleaner.
the complete code would look like that:
def retrieve_python_callback_string_function(root_folder_callback_string, **kwargs):
    else:
Hope this helps
Logan Schwartz, Fx TD @Cinesite Montreal
Edited by logan169 - May 28, 2021 12:08:13
