volume hdri depth map shadows
   6259   6   2
Hi!
Is there a method to render volumes (smoke, clouds etc) with hdri lighting and depth map shadows?
When I use enviroment light with hdri and set depth map shadows I'm getting white smoke without shadows
And raytracing is very very slow for smoke
Use a spot light or a directional light for the shadow casting part.
rob
Gone fishing
raytracing is always really slow with smoke (and a few other things), but you can turn down the ray samples in the Mantra ROP, as well as the volume step size, as a temporary fix.
“In the beginning the Universe was created. This has made a lot of people very angry and has been widely regarded as a bad move.” - Douglas Adams
Thank you!
circusmonkey - thank you for this solution
The only problem is that when I would really get effect like with real hdri shadows I have to use VERY large number of lights
Try experimenting with the Bake Volume SOP to scatter light in the volume.
Hi!
thank you jeff!
Is it possible to use Bake Volume Sop to bake hdri colors on a cloud?
(I cannotfind usage like this in thissop )
volumes dont get shadow information from env lights.
rob
Gone fishing
