Converting a mesh object to a wireframe
   10639   5   4
I would like to convert a mesh object (in my case it is currently a sphere with a type Mesh) to a wireframe. This would be to apply a Polywire SOP to give thickness to every edges.
In other words I would like to remove all the faces and keep only the points and edges of the sphere.
How can I do that? I tried to delete selected faces but it din't work.
Thank you
Video Game Graphics TD
Ends SOP >>> Unroll
You can use a Convert SOP to convert your mesh object to a polygon. Then use a Wireframe SOP or PolyWire SOP.
If you are generating the sphere in Houdini you can just change the Primitive Type parameter to a polygon.
Side Effects Technical Support
opps. Mised the Mesh part.
Use a Carve SOP seting First U and V to 0 and Second U and V to 1.
Thank you for your answers.
Jeff, I tried your suggestion of using an End SOP before sending this thread. Indeed I found an example file were you used it in the thread named HyperNURBS. It didn't work at the time, very likely because my object was a mesh and not a polygon. The use of a Convert SOP mentionned by Jenny solved that and gives me exactly what I was looking for.
The description of the End node in the documentation is a bit confusing to me because parameters are based on U and V information. I guess these are topological U and V and not mapping coordinates, is that it? Are they refering to a coordinate system relative to the whole object or to each polygon of the object?
With Carve I get a wireframe only with a polygon mesh, not a mesh.
If I introduce a Convert node, are results from Carve and End the same? ie do I get curves in both cases?
Thank you also Jenny for mentioning PolyWire. It is not giving the result I want but is quite interesting.
I will continue my experimentation
Here is a more expensive way of doing it, depending on your needs, this can be useful if you want each edge to be it's own primitive.
edit: try carving (or resampeling) the output from the fuse. It gives quite a different result.
wireframe_01.hip (49.6 KB)
