Line between two points
   26690   2   2
Just a simple question. How do I draw a line between two points that i have separated (via delete node) from another geometry?
Now I have a delete node with two points (0 and 1) and need to draw a line between them.
Use the add sop and select the polygon tab, then fill in the pattern 0 1
if you have more than two, use 0-$N
https://vimeo.com/user3251535 [vimeo.com]
https://twitter.com/milansuk [twitter.com]
https://github.com/milansuk [github.com]
