Houdini 11, When?
10287 17 4- td3d
- 28 posts
- malexander
- 5212 posts
This might help ease your anxiousness:
http://www.sidefx.com/index.php?option=com_content&task=view&id=1751&Itemid=226 [sidefx.com]
- fsimerey
- 279 posts
- graham
- 1922 posts
How about now?
http://www.sidefx.com/index.php?option=com_content&task=view&id=1774&Itemid=66 [sidefx.com]
- fsimerey
- 279 posts
- cybermax
- 255 posts
And Houdini 11 Documentation ???
https://vimeo.com/user3251535 [vimeo.com]
https://twitter.com/milansuk [twitter.com]
https://github.com/milansuk [github.com]
- graham
- 1922 posts
- Ratmann
- 110 posts
- td3d
- 28 posts
- malexander
- 5212 posts
- td3d
- 28 posts
- Solitude
- 373 posts
- malexander
- 5212 posts
For ATI cards, I recommend a minimum of the Catalyst 10.3 drivers. I've used the most recent (10.7) with a 2600XT, as well as the 8.723 drivers for the Fire Pro/GL workstation cards (on a FirePro 4800).
H11 uses a large amount of OpenGL 3 code for the viewport, while H10 is mostly back in OpenGL 1.x territory. Updated video drivers are more important for H11.
- td3d
- 28 posts
twod
I've tried it, but totally sucks…no luck…
- malexander
- 5212 posts
- td3d
- 28 posts
twod
Which specific model of ATI card do you have?
ATI Mobility Radeon HD 4570
twod
You can disable the advanced shader by toggling off “Material Shaders” in the Display Options, Effects tab. This will disable the majority of the H11 viewport enhancements, but should work.
thanks, that solved shading problem, but I've still a problem with render region.
Cheers
- ikerr
- 168 posts
Greetings,
Thanks for trying out the Render Region. Could you please submit a bug (instructions at http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=15702) [sidefx.com] outlining the steps needed to reproduce the problem. Also, attaching your hip file would be very helpful. By doing so you'll help us fix the problem more quickly. Thank-you!
–Ian
–Ian
Ian Kerr
3D Software Developer
- td3d
- 28 posts
ikerr
Greetings,
–Ian
already sent on 27/07, and one day later i got the answer…
here the answer from “ Support SideFX”:
This looks like this may be due to problems with your graphics
card/driver.
Our system requirements have changed since Houdini 10. Please look
over this link:
http://www.sidefx.com/index.php?option=com_content&task=view&id=415 [sidefx.com]
What graphics card and driver is in your machine?
