I get errors when i launch houdini.please tell me whats the fix
'CUsers/VIGNES~1/DOCUME~1/houdini11.0/config/Icons/SVGIcons.cache' corrupted?
warning: failed to load ‘VIEW_lighting_headlight.svg’
‘CUsers/VIGNES~1/DOCUME~1/houdini11.0/config/Icons/SVGIcons.cache’ corrupted?
warning: failed to load ‘VIEW_display_lock_camera.svg’
warning: failed to load ‘NETWORKS_rop.svg’
warning: failed to load ‘TOOLS_flipbook.svg’
warning: failed to load ‘TOOLS_render_region.svg’
warning: failed to load ‘TOOLS_view.svg’
warning: failed to load ‘TOOLS_snap.svg’
warning: failed to load ‘TOOLS_snap_point.svg’
warning: failed to load ‘TOOLS_snap_curve.svg’
warning: failed to load ‘TOOLS_snap_grid.svg’
warning: failed to load ‘TOOLS_handles.svg’
warning: failed to load ‘TOOLS_scale.svg’
warning: failed to load ‘TOOLS_rotate.svg’
warning: failed to load ‘TOOLS_move.svg’
warning: failed to load ‘TOOLS_select.svg’
warning: failed to load ‘TOOLS_select_dynamics.svg’
warning: failed to load ‘TOOLS_select_particles.svg’
warning: failed to load ‘TOOLS_select_faces.svg’
warning: failed to load ‘TOOLS_select_objects.svg’
warning: failed to load ‘VIEW_layout_single.svg’
warning: failed to load ‘VIEW_show_ghosted.svg’
warning: failed to load ‘VIEW_smooth.svg’
warning: failed to load ‘BUTTONS_sync.svg’
warning: failed to load ‘BUTTONS_unpinned.svg’
warning: failed to load ‘NETWORKS_scene.svg’
warning: failed to load ‘BUTTONS_forward.svg’
warning: failed to load ‘BUTTONS_back.svg’
warning: failed to load ‘BUTTONS_pane_menu.svg’
warning: failed to load ‘BUTTONS_maximize.svg’
warning: failed to load ‘BUTTONS_new_tab.svg’
warning: failed to load ‘BUTTONS_delete.svg’
– 1 ———–
errors when loading houdini
13430 14 0- vigneshwarviswanathan
- 32 posts
- malexander
- 5212 posts
- 32 posts
twod
Remove the SVGIcons.cache and SVGIcons.cache.serial files in your $HOME/houdini11.0/config/Icons directory.
even after i removed the files,i still get errors
please help me out
warning: failed to load ‘BUTTONS_displayoptions.svg’
warning: failed to load ‘VIEW_display_applyto_all.svg’
warning: failed to load ‘VIEW_display_background.svg’
warning: failed to load ‘VIEW_display_point_attribute.svg’
warning: failed to load ‘VIEW_display_objectnames_name.svg’
warning: failed to load ‘VIEW_display_particle_origins.svg’
warning: failed to load ‘VIEW_display_vertex_grips.svg’
warning: failed to load ‘VIEW_display_hulls.svg’
warning: failed to load ‘VIEW_display_primitive_numbers.svg’
warning: failed to load ‘VIEW_display_primitive_normals.svg’
warning: failed to load ‘VIEW_display_point_numbers.svg’
warning: failed to load ‘VIEW_display_point_normals.svg’
warning: failed to load ‘VIEW_display_points.svg’
warning: failed to load ‘VIEW_display_objects.svg’
warning: failed to load ‘VIEW_shadow_quality_high.svg’
warning: failed to load ‘VIEW_lighting_objlights.svg’
- malexander
- 5212 posts
- 32 posts
- 32 posts
- malexander
- 5212 posts
- 32 posts
- Infernalspawn
- 229 posts
- 32 posts
- edward
- 7899 posts
- 32 posts
- yalla
- 3 posts
edward
If you haven't saved anything in it, I'd just try deleting the houdini11.0 directory altogether. Or Cut/Paste move it to somewhere else.
I had the same problem with Houdini 12.5 on a Windows 7 machine. I followed your advice, copied and pasted the houdini folder altogether from one drive to another and now Houdini seems to be running normally.
Thank you!!!
- Marcola
- 6 posts
The last suggestion did work indeed. Just faced the same problem as mentioned by vigneshwarviswanathan. Not sure why something would go corrupted with Houdini Apprentice after 3 months of solid daily use. Great piece of software though. Keep refining it SideFX! Thanks.
Windows 7
Core i7 2.8ghz
16gb ram
NVIDIA Quadro K2100M
Samsung 250gb SCSI
Windows 7
Core i7 2.8ghz
16gb ram
Samsung 250gb SCSI
- Patrick Woo
- 1 posts
vigneshwarviswanathanInfernalspawn
are the sub folders and files of /houdini*.* write-able as well ?
whenever i right click on the folder and untick read only in the houdini folder.
Its not getting set.It gets changed.could you tell me how to make it writeable?
thank you
My problem was that the Houdini 16.5 folders and sub-folders were set to read-only.
I could disable their read-only by unchecking in folder / sub-folder properties, and immediately start Houdini, but by the time Houdini loads, the folders are reverted back to read-only.
Finally, I found out that my Bit Defender protection software was doing this. In my version of Bit Defender, I had to go to my Application Access, to allow Side Effects applications to access the content of those folders.
Phew!
