I'm trying to copy some geometry(say, pre-built floor of the building) with Copy SOP for further demolition with RBD, and ran into a problem with grouping: Copy SOP actually does not copies all the groups from the source for each copy, it just adds all the copied primitives into the same groups, making DOPs think, that, say, all the tables on all the floors is a single object, which is obviously not what i want.
Is there any way to copy all the groups together with geometry?
Copy SOP and groups
5276 8 1-
- Mudvin
- 66 posts
- kuba
- 345 posts
- mawi
- 247 posts
Mudvin
Are you using the “Create output groups” or stamping?
Here are a few examples.
- Mudvin
- 66 posts
kuba: i think we will have the same problem here - dynamic solver gonna count equally colored objects on different floors as a single object.
mawi: thanks for examples, but i think single sphere not gonna work here. Imagine, there's merge of 4 sphere with different group names fed into copy sop, and somehow not only geometry, but also groups have to be copied by copy sop. Workaround is to recreate all those groups again in copy sop result, but the problem is that houdini counts the sides and caps of shattered pieces as a separate objects.
example scene attached.
wbr, Mudvin
- Anonymous
- 678 posts
- Mudvin
- 66 posts
- Anonymous
- 678 posts
Thats a good start http://www.sidefx.com/index.php?option=com_content&task=view&id=881&Itemid=254 [sidefx.com].
- Mudvin
- 66 posts
- wrc-racer45
- 1 posts
mawithanksMudvin
Новости ралли на сайте wrc news [wrc-info.ru]
