Rotate Animation expression problem
   7842   5   1
I'm trying to do a simple transition effect using the copy sop…
its a box copy onto grid…and then using copy stamp to random rotate boxes on y axis, but i have a problem with the expression….
i want to make a 360\180 random rotate on boxes but i want to stop at the end of animation with all boxes stopped on the same status….but all boxes have a differente rotation…know what i mean? i want to control/vary rotations speeds too….
i dont know if this is the best way to do this kind of effect….if have a better way please let me know
i thinks this its a simple way….
sorry for bad english, hope you help me
i'm sending the file…
thanks
rotateboxes.hipnc (186.4 KB)
If all the random rotations are within 0-360
try using the clamp function.
this is not a science fair.
And how can i use it?
instead of stamp ? or rand?
You can do a lot of good custom stuff with a VOP SOP, you have to think a little in exchange of a good amount of control.
In the file I've created a parameter that you can have a control of what frame to start.
Made in H11.
I hope it helps.
rotateboxes_803.hipnc (300.1 KB)
https://vimeo.com/user2163076 [vimeo.com]
Thanks for the help!!
i really need to study your file now….because i'm pretty newbie on coding stuff with vex. But i like your solution!!
if you can, add me on msn…. dudufa@hotmail.com
its hard to find a brazilian that uses houdini!!
thanks again!
cya!
Neoblink
cya!
That's true, lucky for us
