opening channel editor immediately causes houdini to hang
   3216   2   1
Something odd happened this evening… I had been using the channel editor repeatedly. Then suddenly, opening the graph editor hung houdini. Now it happens even if i open a fresh file with only one geometry node with one keyframe.
Check out the attached image. When the channel editor opens, this is what I see. Be sure so check out the value in the lower left hand corner. That value is consistent with each hang.
Is there something I can clear, a preference file to delete, or some textport wizardry I can use to “reset” the graph editor?
chris
Picture 1.png (35.5 KB)
http://toonlets.com [toonlets.com]
Ah, deleting hchanneleditor.pref seems to've fixed my problem. Whew!
hRangeLower := 6420572571359443419136.000000;
hRangeUpper := 1764642055285661665067008.000000;
hRangeMaxLower := 1.000000;
hRangeMaxUpper := 1764642055285661665067008.000000;
