using vop to create renderman shaders
   3806   5   1
Hi
How could I use vop network to create renderman shader in Houdini 11
Creating RSL SHOP types under /VEX or in VOPnet?
Using VOPnet
It's the same.
Sorry if I was not clear enough but I meant you should just create rsl SHOP type and put rsl code inside.
Thank you peliosis for your reply
Hi again
Yesterday I used houdini 9.5 and everything worked smoothly but today when I test it whit v11 something looks weird. lets explain it clearly:
I use material sop to assign shader. In sop level I create this network:
shopnet/vopnet/rsl_surface and create my shader there. but when I want to assign the shader from material sop the rsl_surface operator isn't accessible and I could select only the shopnet operator there.
how could I choose rsl_surface from material sop.
