hi all..
Does anyone know if it is possible to do multi-pass with specific (non-standard) EXR channels within COPS?
I can load up an EXR image in the File node, but “There are no input options defined for the OpenEXR format” appears in the dialog. Not a problem as I can always render separate EXRs or jump to Nuke.
thanks!
EXR channels in COPS
6629 3 2- david_aiken
- 86 posts
- malexander
- 5212 posts
- david_aiken
- 86 posts
- 3di2017
- 12 posts
twod
The File COP will load all channels present in the exr file. You can use a delete COP to extract individual channels out, or rename to move color channels into the C plane, though many COPs allow you to select which planes to use or cook. So in short, yes, it's possible to do what you're saying.
is this still the way to extract individual channels?
