Hi
I am trying to load COPS image as the camera background, but for some reason this expression does not work
“opimg/comp1/_OUT”
_OUT is a null connected to the defaul.pic image. On the otherhand
“”opimg/comp1/default_pic" doesn ot work either.
Are there any limitations with COPS nodes as far as scene level pulling of images goes?
thanks
op:/ operator and Camera background image?
22927 14 7- kursad
- 88 posts
- old_school
- 2540 posts
The use of the op: syntax to pull a COP image as a background “should” work but I am finding it troublesome myself. Submitted the bug ID=42458.
If I use the opimg/comp1/butterfly1_pic in the viewport Display Options Dialog > Background Tab Filename parmeter and enable Display Background Images it does work so I suspect there is an update bug with the viewport itself.
The “Enable Background Image” toggle on the camera should toggle on the Display options “Display Background Images” toggle…
- kursad
- 88 posts
- malexander
- 5212 posts
You need to use the View Roto parameters to set up a background image in the viewport, via the node's Edit Rendering Parameters menu item. These used to always exist on camera nodes, but were relegated to ‘extra’ parameter status a while back. They are in the Viewport Display > View Roto folder.
Apparently they're hidden well enough that when a BG image was added to mantra, a new parameter was added instead of using these parms. These two should be consolidated.
- splitpoint
- 57 posts
I had put together a quick tutorial for importing syntheyes data a while back that included a section on setting up a background image for roto. It's for Houdini v10 but the process is the same in v11. One of these days I really should upload it to vimeo. For the time being you can find it here:
File has now uploaded to Vimeo here:
http://www.vimeo.com/17870587 [vimeo.com]
There is an error at 2:10, I say “attribute” but I really mean “parameter”
Al
Al
Edited by - Dec. 15, 2010 23:22:27
- kursad
- 88 posts
- kursad
- 88 posts
twod
twod yes that is very helpful, however it does not help with rendering a COP image as background?
- oldiesgoodies
- 20 posts
- insania
- 16 posts
- dvfedele
- 33 posts
- grayOlorin
- 1799 posts
- Anonymous
- 678 posts
- Edin Gacic
- 1 posts
So now I have the problem in latest Houdini release can't view background? And roto option is gone? what to do … how do I set up a background so I can see my tracking data against it linked to a camera? I am moving PFtrack data via cmd script.
I imported jpg sequence and it is working now…. maybe a limit with dpx float or something in the viewport?
Also when you have more then one camera it does not work
many bugs here
many bugs here
- Michela Ledwidge
- 12 posts
- nicholasralabate
- 114 posts
It seems that “Enable Background Image” does not toggle the Display background image in 18.0.366… or am I misunderstanding what the “Enable Background Image” checkbox is supposed to do…
EDIT: Oops, that's for render time… will RFE changing the name to “Render Background Image”.
Edited by nicholasralabate - Feb. 6, 2020 16:50:03
