Using Eclipse in Linux for Houdini 11
   4820   4   1
Hello!
Trying to compile custom x64 plugin for Houdini 11 using Eclipse.
Same code for Houdini 10 was compiled just fine.
However, got some strange errors.
For example:
cast from ‘const void*’ to ‘uint’ loses precision
file $HFS/toolkit/include/SYS/SYS_Math.h in line 969
and
class ‘UT_OStrStream’ does not have any field named ‘ostrstream’
file $HFS/toolkit/include/UT/UT_NTStreamUtil.h line 58
The strangest thing for me is that this errors are not about my code but about code that comes with Houdini.
Anyone expeirenced something similar?
Should I do any additional steps to compile plugins for Houdini 11?
I'm using Eclipse Version: Helios Service Release 1
Build id: 20100917-0705
Linux Open Suse 2.6.34-12-desktop x86_64 GNU/Linux
gcc (SUSE Linux) 4.5.0 20100604
TD @ Mr.X Inc
Just needed to add some additional #define statements to my project and it's ok.
TD @ Mr.X Inc
Hi Sergey,
I am facing the same situation. Which #define statements did you add?
Hi Ben,
Currently don't have Linux workstation around to check but as far as I remember it is vitally important to have correct gcc version.
Make sure you use same gcc version as your Houdini build on Linux.
Gcc 4.3 if I'm not mistaking.
TD @ Mr.X Inc
I'm facing the same situation, my Houdini version is compiled with gcc4.4 and I made sure i'm compiling with gcc 4.4, but still the problem is there …
Any help would be really appreciated.
Cheers
