attribtransfer and the sop solver
   Views 8071   Replies 5   Subscribers 1
Hi there,
I would like to know why I cant transfer the attribute with the sop solver?
cant make the transfer resist.
Thanks a lot!
enclosed the hip file.
attribtransfer.hipnc (152.7 KB)
you have Use Deforming Geometry on RBD turned on, that means that every timestep the geometry is updated from SOPs and thus discards every color change you've made in SOP solver
try to use just object level animation if you need this to work that way.
It is possible to make it work on deforming geometry too, but as long as you have rigid animation, object space transforms are best
attached very simple example
attribtransfer_fix.hipnc (127.4 KB)
thanks tamte,
It was just a test szene, I need that with a deforming geometry… how can I achive that?
thanks!!!
here it is with deforming geometry
sopsolver_attribtransfer_deforming.hipnc (148.2 KB)
Thank you tamte!!!
Hello i have a problem like u had, i want to transfer color to an animated model that has been animated in Maya, and the guy send me an alembic file with the animation, but i dont know how to make the solver work with the animated geometry even if i say that is a deforming object.
Edited by deilvad - June 12, 2016 11:27:11
transfer_problem.hip (295.9 KB)
