Hi there I'm following the clouds and fractals tutorial on cmivfx
and I've become a bit unstuck when trying to export and import the i3d file format.
I render out an i3d file and re import it into a 3d texture volume VOP . But it does not appear in the view port. I've tried using the project files from the chapter but still have the same problem.
I'm trying to work out whether it's operator or computer error.
Does anyone have a project with an i3d file that definitely imports and displays on their system that I can have a go at using?
thanks
John
i3d file import difficulties
31044 29 6- HUGHSPEERS
- 82 posts
- HUGHSPEERS
- 82 posts
- Barad_Dur
- 46 posts
Hi there,
I am having the exact same problem across every build beyond what he is using in the Fractals tutorial. I am currently using 11.0.685. I have rebuilt the network twice now and I get bupkiss.
Can you upload your rendered .i3d files here so I can try and view them with an isosurface sop? Any other help would be awsome. Thank you.
David
David
- HUGHSPEERS
- 82 posts
- Barad_Dur
- 46 posts
- HUGHSPEERS
- 82 posts
Hey David
I uploaded a file with some i3d files here in a project where I'm trying to apply
animation to the fractal clouds vex shader.
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=21715&highlight= [sidefx.com]
so you can try that.
The first thing I did when I was having trouble was downloading the project files from the Cmivfx website, and tried exporting the i3d from those, have you done that yet?
Also another thing to check is that your bounding box is correctly set up , if it's not you'll export nothing. I did that a few times. A clue would be checking the data sizes of the exported files to see if there's anything in them.
- claudio_101
- 121 posts
Hi David,
I'm not sure if you still need it. But I also had my difficulties with the i3d files.
After asking around I was advised to recreated the geo2i3d rop.
In attach my setup which works very well now.
Here is a test render I did: http://vimeo.com/21129148 [vimeo.com]
Cheers
Cheers
Available for new projects
- mzigaib
- 976 posts
I am also having problems with the i3d texture.
I tried to remake the geo2i3d rop and still the problem persists, I am using build 581.
When I try to render the cloudDensity and the cloudGradient both files get the same file size and when I use them on the cvex nothing appears on the viewport like in the video.
Any ideas?
Any ideas?
- mzigaib
- 976 posts
- claudio_101
- 121 posts
- mzigaib
- 976 posts
Thanks for the reply.
I am using the file provided for CMIVFX, I just click in the render button to recreate the i3d files, the problem is when I try to load inside the cvex in the 3D texture node, nothing appears.
I also tried to manually recreate the scene and the problem is the same.
Fell free to take a look and see what you can get.
- HUGHSPEERS
- 82 posts
- HUGHSPEERS
- 82 posts
- mzigaib
- 976 posts
- HUGHSPEERS
- 82 posts
- Neil78
- 275 posts
- claudio_101
- 121 posts
- mzigaib
- 976 posts
- mzigaib
- 976 posts
- Neil78
- 275 posts
