Assigning flapping birds to sprites
   3206   1   2
Hiya mates!
I had a thorough look at the butterfly sprite tutorials … but I have a problem cycling my flapping-textures.
Suggestion: What if I assign each sprite a cycle (with a randomised offset given it at birth) and then go through npoints for each frame and cycle the texture assigned to each sprite?
Any thoughts?
Cheers, Jostein.
Jostein
Hiya mates!
Any thoughts?
Cheers, Jostein.
Modulo is at the heart of cycling, e.g.
$F%12
Assuming a 12 frame cycle, you'll get values 0 -> 11 out of it. Then, just add some offset:
($F+34)%12
Typically, if you have a bunch of objects, all doing the same thing, you can use opdigits(), as in:
($F+opdigits(“..”))%12
However, that only puts them at one frame appart each, so instead, refine the expression to:
($F+int(fit(rand(opdigits(“..”)),0,1,0,12)%12
That way, the rand() is essentially generating a random value that's zero to number-of-frames-in-cycle.
– Antoine
Antoine Durr
Floq FX
antoine@floqfx.com
_________________
