This is killing me… how in the world do i create an hscript function attached to a value to return a different number based on frame? i.
if ($F == 1 ) then
set var = 1
else
set var = 2
endif
return var
please help! I can'f find documentation anywhere that works
Hscript inline function
5137 5 0- liquidsolid
- 12 posts
- tamte
- 8786 posts
- liquidsolid
- 12 posts
right but I don't want a simple expression…… I have 5 if statements that I want to evaluate and return different values.
so something like this:
if ($F == 1, 1, 0)
will give me 1 if it's true and 0 if it's false
if i do this:
if($F == 1, 1, 0) || if($F == 5, 10, 0)
it will only return a 1 or a 0 not 1 or 10….. I want to do an inline function but I can't figure out the sytanx in hscript. I know how to create a python function to do this but not hscript
if ($F == 1, 1, 0)
if i do this:
- tamte
- 8786 posts
then you can either use nested expressions
if($F == 1, 1, if($F == 2, 4, if($F == 3, 6, if($F == 4, 8,if($F == 5, 10, 0)))))
or inline syntax would be
float v = 0;
if($F == 1) {v = 2;}
if($F == 2) {v = 4;}
if($F == 3) {v = 6;}
if($F == 4) {v = 8;}
if($F == 5) {v = 10;}
return v;
float v = 0;
return v;
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- liquidsolid
- 12 posts
- Anonymous
- 678 posts
You can write your own expression functon. Just go to EDIT -> ALIASES and VARIABLES -> Expressions and write whatever you want.
Example:
float test(float frame, string text)
float len = strlen(text);
if(frame <= 10)
return 2;
else if(frame > 10 && frame <= 20)
return 21 / len;
else if(frame > 20 && frame <= 30)
return 3.4;
else
return len;
Then you can call this expression from anywhere by just typing function name and pasing parameters. Note that you don't need to use $ sign to call your function.
test($F, “Hello”)
Example:
if(frame <= 10)
return 2;
return 21 / len;
return 3.4;
else
return len;
test($F, “Hello”)
