which one is Rename node hotkey in veiwport
   5847   6   1
in network view, is there any rename node hotkey?
so i don;t need to move my hand from keyboard to mouse for select rename then comeback to keyboard to type again.
with your cursor in the network pane right mouse button to bring up the menu and you see that Rename has the hotkey Alt+w written on the right hand side of the menu.
Training Lead
www.sidefx.com
not that rename, i mean the function like “click on the name to rename” without moving hand to mouse.
alt+w need to move the hand to rename window.
:shock:
waiting for someone to reply the post
Doesn't look like there is a simple hotkey to initiate a rename of the selected node via the node label/field, only the previously mentioned hotkey to pop up the rename dialog.
Hi i am using windows 10 and its F2 when node is selected. Hope it helps…..
DmitrySurini
Hi i am using windows 10 and its F2 when node is selected. Hope it helps.....
NICE! Thanks a lot.
Was loking for this.
Only 6 years later.
