latest Houdini builds
6069 9 2- Big-Chuck
- 37 posts
I cannot get the last 4 or 5 builds of Houdini to install on my HP 310 touchsmart computer. All seems to go well until I try to run the program and then it comes up with this window that says it cannot install the icons, over and over it runs the same fault and when Houdini opens up none of the icons for anything are viewable. Any ideas? I hate not being able to use Houdini. I also have tried disabling the windows firewall and my anitvirus program with no change.
- fsimerey
- 279 posts
- Big-Chuck
- 37 posts
- eitht
- 257 posts
- eitht
- 257 posts
- Big-Chuck
- 37 posts
- edward
- 7871 posts
Hmm, it sounds like you've already have your Apprentice licenses installed so that Houdini comes up right? Then try doing this sequence of steps (assuming Windows Vista or above) to fix the icons:
1. Install the latest production build of Houdini 11.
2. Locate your houdini11.0 folder. Right-click on your C: drive in Windows Explorer and do a full file search
3. Rename them all to something else like houdini11.0-old
4. Now start Houdini AS A REGULAR USER. The first time this happens, it will take a while as the icon cache is built. You should wait for this process to complete and the main Houdini window pops up.
- Big-Chuck
- 37 posts
- edward
- 7871 posts
Big-Chuck
Below is the error message that keeps repeating in the Houdini Console box
Warning: CUsers/Big-Chuck/Documents/houdini11.0/config/Icons/SVGIcons.cache.serial is not writeable
This looks like a permissions problem. Did you try renaming that particular houdini11.0 and NOT starting Houdini as Admin?
- Big-Chuck
- 37 posts
