Hi
Houdini version 10.0.8835
I have a simple question.
I have a animation at my character but i want to remove it and start a new one. How do i do that?
Remove an animation
11206 6 1-
- Robin0217
- 50 posts
- uniqueloginname
- 330 posts
Hi, do you want to remove the animation data? If so, this will at least partially help you..
On any channel that has keyframes, for example a text box coloured cyan or green (showing it has keys on it), Right-click -> “delete channels”. This will remove the keyframe data for that property.
There might be a way to delete all channels but I do not know.
- Robin0217
- 50 posts
- Soothsayer
- 875 posts
- uniqueloginname
- 330 posts
- zarti
- 330 posts
- rmagee
- 1341 posts
Select the character node - In the Parameter pane, RMB-click on the icon at the top left and choose Delete Channels from the menu. this will delete all the channels from the node.
If you have multiple object selected then only the first one will have its channels removed - you need to do this one node at a time.
Robert
Robert
