Include Frame Counter in Render
   7268   3   4
Is it possible to include the frame info that shows up in MPlay in the upper left in an exported image or video?
Most of My Houdini Renders [flickr.com]
My System [evga.com]
You can parent a geo with a font sop in it to the camera, position it so it's visible in frame, then attach a constant shader to it, and use `$F` as the text (not the backticks, just next to the “1” key).
Sean Lewkiw
Machine FX - Cinesite MTL
Or overlay a text in COPs to have always an option if you change mind.
you could also use the watermark application in the post frame script:
for example:
unix hwatermark -x 4 10 -m “$WEDGE” `chs(“vm_picture”)` `chs(“vm_picture”)` $HFS/houdini/fonts_texture/Fixed-Bold.24
This example is from:
http://www.sidefx.com/docs/houdini11.0/nodes/out/wedge [sidefx.com]
Koen
