Houdini 11 on Mac unable to display icons
   4321   6   1
I just downloaded the latest version of Houdini 11 on my mac and the icons are not displayed. I tried redownloading it a few times but it did not work. Is there anyway to resolve this ? Thanks .
Screen shot 2011-05-22 at AM 12.59.41.png (146.8 KB)
Do you have X11 installed on your OS X? If you don't you can install it off of your OS X install DVD. Once you have that installed, you probably want to remove your $HOME/Library/Preferences/houdini directory so that correct icons get generated when you restart Houdini.
I installed it on my OS but i dont see houdini directory when i go to $HOME/Library/Preference.
I just managed to find the Houdini Directory and deleted it and it worked. Thanks so much
Hi… Im having same issue here..
apparently X11 is already installed in the latest macbook pro versions.
I deleted the “houdini.env” file under /Library/Preferences/houdini/11.0
I restarted houdini, but I still cant see the icons.
Any idea?
Screen shot 2011-06-01 at 8.41.10 PM.png (253.1 KB)
Try deleting not only the houdini.env file but the whole 11.0 folder. Also Houdini may be using $HOME/houdini11.0/ as the configuration folder, so try deleting that folder as well, if it exists.
Great…
It didnt work at first but I just had to complete reboot the system and I got the icons working fine!
Thanks! happy again!
