math problem
   2905   2   0
I've got problems with the understanding of whats going on in my network. I need to know the in and outputs of the nodes. I've attached an image of the network. Its a CVEX Shader for clouds. Is there any way to quickly check what number and what datatype is going into and gets out of a node?
Edited by - May 25, 2011 16:10:35
try the “print” vop node and plug it into any output to get the values from your VOP node, the output will get printed in your shell.
to get the data type I guess the color coding should help you already?
.. if that's what you mean of course.
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
thx. this node gave me enough information to solve my problem
