hi all
i'm having some troubles rendering instanced geometry with prman, i've tested with mantra and the problems are the same.
I'm using a Instance POP and when i render with a renderman ROP, or Mantra ROP, the geometry doesn't appear, instead the aprticles are rendered as spheres.
If i use a point SOP, and there i instanced the geometry the result is the same.
But if i instance the geometry in the object level it works, but i can't apply a shader to the instanced geometry.
In the particle network there isn't any render POP.
Somebody knows what is wrong, what is the best method to instance geometry into a particle system?
Problems rendering instanced geometry with prman
2798 0 1- lisux
- 581 posts
