Hi there,
I was wondering if there was any detailed info on what type of hardware would be supported for GPU based pyro acceleration?
Thanks,
Andrew
Houdini 12 GPU acceleration details
125618 27 2-
- akim_hobo
- 21 posts
- malexander
- 5227 posts
You need a GPU capable of supporting OpenCL. On the Nvidia side, that would be a Quadro x000 series (non-FX quadro; 600,2000,4000,5000,6000) or a GEForce 400 or 500 series. For AMD, you need a FirePro card (not FireGL) or a Radeon 5000 or 6000 series GPU. Intel's graphics are currently not able to support OpenCL, but they do have a CPU-oriented CL library which may work with Houdini in the future.
- Alejandro Echeverry
- 691 posts
hi!!!
I have a Quadro 5000, but i think will be not enought for a sim, because of the memory that card have 3.5 gb. I'm wrong?
- adrianlazar
- 102 posts
- malexander
- 5227 posts
alejandro
It has 2.5GB of VRAM, which is good enough for some fairly large sims (320x320x320 is the highest I've seen). The exact limit may depend on how many screens your card is driving, their resolution, and other apps using video memory.
adrianlazar
Is the mobile version of amd radeon supported? Like the AMD Radeon HD 6750M from the new MPB?
Mobile variants of the desktop GPUs I noted above will run OpenCL. Their main downfall is a shortage of video memory which will limit the size of the sim you can run. A GPU with 512MB of VRAM is generally only capable of running a 128x128x128 sim. The lower clocks and fewer shaders will also decrease performance quite a bit.
- adrianlazar
- 102 posts
- 691 posts
Thank you!!!
- akim_hobo
- 21 posts
- deadalvs
- 196 posts
- sanostol
- 582 posts
another question that I have in my mind is what happens when You use 2 or more tesla cards. The size of the sim that a tesla card can handle depends on the memory of it, but do the memories of 2 cards add or not. My guess is not, as as soon as the card has to exchange data it slows down. but would be interesting to hear more about it from the sidefx people
Martin
Martin
- AndyAl92
- 15 posts
- malexander
- 5227 posts
- patar
- 280 posts
- ranxerox
- 35 posts
- malexander
- 5227 posts
- patar
- 280 posts
- Mr_Bill_Jee
- 1 posts
- exelon
- 4 posts
Hi folks, this is my first post here…gonna be on H12 once out
. In order to plan ahead, my GPU-related question is whether it will be possible to specify which GPU ( or simpler: card present in the system ) will be used for simulation. I understood that there´s only one that can be used…but is this necessarily going to be the graphics adapter, or can i let´s say have an FX5800 for display and a Tesla 2070 for sim? That´d be great to know, thanks a lot in advance!
- malexander
- 5227 posts
Nvidia's newer drivers automatically route compute tasks to the Tesla card, and graphics tasks to the Quadro, if you have two in your system. This doesn't work with GEForce cards, however; just Tesla+Quadro. It also won't work with QuadroFX cards - just the newer Quadro 600, 2000, 4000, 5000 and 6000.
You can manually set the GPU with HOUDINI_OCL_DEVICENUMBER as well, which is what you'd need to do for your QuadroFX/Tesla combination.
- exelon
- 4 posts
