Sand Volume Erosion Test
   15233   10   2
http://vimeo.com/30949913 [vimeo.com]
Hi there~
I just tested surface erosion using levelset in houdini.
All of the detailed methods are in Daniel P.Ferreira's technical demonstration.
wonderslime.com/​
Cool! I had forgotten how awesome those sandman effects are!
Thanks for the reference as well
Toronto - ON
very cool, hope you bring us more!
cheers!
https://vimeo.com/jacyslin [vimeo.com]
thanks~ rafaels, dim1984kimo
Can you tell about something.. ?
chose
Hi all, could someone explain what exactly level set are out of interest ? As this looks like a sop solver effect transferring attributes to create erosion, wondered if I'm missing something.
Lyonz
In Houdini-parlance, they are Signed Distance Fields, a.k.a. SDF's.
So basically Signed Distance Fields are layers of the same volume ? aka level sets
Lyonz
Nope. SDF is a volume telling how far from the nearest surface you are at any point in space. Subtracting/adding from the value gets you a new parallel surface which is inside/outside the original surface - pretty handy for erosion-type effects.
http://www.sidefx.com/docs/houdini11.1/model/volumes [sidefx.com]
http://www.sidefx.com/docs/houdini11.1/nodes/sop/isooffset [sidefx.com]
sorry for late reply
Here is the file~
As you can see, that file consist of complicated node as my lack of skills.
However, you will get fundamental idea how I achieve that motion in houdini.
Edited by - Feb. 12, 2012 20:38:09
erosion.zip (707.9 KB)
thanks a lot .. it's very good/
chose
