Emit light from Pyro
10879 6 2-
- nzabala
- 66 posts
Hi, i´m trying to understand how can I illuminate my scene based on the fire of the pyrofx. I tried creating points and using them as geometry light but couldn't make it work. Also trying to use those points as photons but also failed. Is there a better workaround to do this? Thanks in advance!
NicoZ
- nzabala
- 66 posts
- fsimerey
- 279 posts
- Dobin
- 30 posts
- nzabala
- 66 posts
- nzabala
- 66 posts
Tried both methods. In my case illuminating with the pyro shader (diff1 vol1) took a lot of time to render 1 frame.
I rendered the point clouds with the pyro shader, load the fire points, reduce them a little and added a Point SOP to instance a light template wich shader is a ASAD light. That did the job for me
Thanks a lot guys for helping me in this one, i´m working on a personal project that im now more close to finish. Hope this post helps someone else also!
NicoZ
- hopeschroers
- 57 posts
