I am trying to do something like this using the Bend SOP and I tweaked all the parameters but still not exactly able to get this simple result:
Any ideas?
How to use bend to get a bent tube?
13155 10 3- magneto
- 131 posts
- ragupasta
- 349 posts
- grayOlorin
- 1799 posts
- magneto
- 131 posts
- pbowmar
- 7046 posts
- magneto
- 131 posts
- magneto
- 131 posts
- roughsporty
- 191 posts
Use the rk Omni Bend from Exchange:
http://www.sidefx.com/exchange/download.php?fileid=722&type=OTL [sidefx.com]
It will do the trick :-)
- magneto
- 131 posts
Wow I am amazed, I got the result I wanted very easily with rk Bend SOP.
It would be even cooler if I could modify params like center in the viewport, using the show handle tool.
Can this be written in a SOP to work like that? Just curious if Houdini allows this sort of functionality for 3rd party SOPs.
Thanks.
Thanks.
- cancKorin
- 1 posts
Hi, i'm new with Houdini and today try to prepare model using Bend deformer and wondering that it not work as other 3D software like Cinema 4D or Maya. But with some experiments i found solution how to bend tube like magneto shows on topic start. It is very simple just don't set value of 0 to Capture Direction Z, it may be 0.0000001 and it works fine but not 0
Hope it helps someone
- dirtrobot
- 1 posts
ВадимМикитюк
Yes it did, I had no idea until this!
