renaissance brick work issue
   Views 3617   Replies 3   Subscribers 2
hello everybody,
its been a while since ive gotten truely stuck with houdini. however, it seems that time has arrived that i must seek council from the more experienced users.
what i am trying to acomplish is a renaissance brickwork pattern
what i have managed to get so far is this:
this was done using two foreach SOPs. the first one to create a row of bricks all with random widths. Then another one to stack them on top of each other with different heights.
Now what i cant find out how to do is give the stacked rows different widths than the original one.
I have attached the file in case i have not been clear.
thanks in advance for any help ^^ i am truly up a creek without a paddle here
[imageshack.us]
bricks.hipnc (58.3 KB)
See attached,
I tried making random points along a spline then snapped them to a fixed minimum width using the fuse SOP.
brickwork.hipnc (97.7 KB)
Hi Chris,
I used yet another approach. I tried doing it with the copy sop.
Two lines, one for the vertical bricks and one for the horizontal bricks are used as a reference. The points on both lines are shifted with a noise to get the randomness and the size in between the points is calculated to get the height and the width of the bricks.
Inside the geometry you'll find a control sop with different parameters to play around with.
Cheers
Screen shot 2011-12-05 at 10.22.14.png (41.1 KB)
bricks_v2.hipnc (159.3 KB)
Available for new projects
ooh very cool, thanks guys ^^
