HELP! URGENT!!! Saving a bgeo file
   2981   2   1
Hi, i have created a sketchup file that i intended to import into Houdini.
I have exported the sketchup file using FBX format and imported it into Houdini.
However, I am unable to manipulate the imported geometry, as the file is not within the GEO SOP. How do i go about solving this?
Thanks. I have attached the file, Is converting it into BGEO the only way?
highway_road3.hip (852.6 KB)
select all the geometry and click extract on the shelf. This will place all the geometry into a new geometry node which you can manipulate.
Thank you so much it worked wonders.
