[help] Reference previous copies size/attributes
   3063   1   2
I have been trying to work out for quite some time if it's possible when using the copy sop to reference the previous copys size/boundingbox/position. I'm not sure if this is quite a complicated task or extremely simple.
I have tried using the foreach sop to create an attribute for each copy and then translate each primitive using the created values however I can't seem to get it to work. I was wondering if someone could point me in the right direction.
Hi, maybe you could try the SOP solver. Peter Quint has made a video explaining it:
http://vimeo.com/6660287 [vimeo.com]
hope it helps!
- Rasmus
