Viewport display options
   2998   3   1
Hi, i am trying to do a print screen of an object that i have created, Is there a way to display the object “ flat” instead of “ flat shaded”, i am trying to off the shadow display.
it seems that other options like wireframe will not have the shadow activated, however i need the print screen to show the object as visibility “flat”. Is there a way around the shaded display option, while keeping the flat display option?
You mean without lighting?
without shadows
Easiest way is to add an ambient light, turn off the head light (small yellow icon on top right of scene view panel) and set smooth shaded
If you also create a material that uses a flat texture as the color (ie constant) this should work
-G
