Help disappeared
   3637   6   1
I'm running ApprenticeHD at home on my MacBookPro. When I upgraded to OSX Lion Houdini stopped working so I uninstalled and downloaded the latest build. Now the help is not working at all. When Safari launches I get an error saying:
Safari can't connect to the server. Safari can't open the page "http://localhost:0 [localhost]“ because Safari can't connect the the server ”localhost".
Any way to fix this?
Thanks,
Matt
What's the fix?
Never got an answer. I ended up manually entering the URL to the docs on the sidefx site in the prefs. Not a great solution since context sensitive help does not work… Only global. Just glad that our full version at the office works correctly.
Sidefx????
Yeah no context sensitive help is a big bummer. Like you I'm lucky it works in the office, but I want/need to be able to do some further investigation at home.
Search the forums, I think it was something like upgrading to the latest XCode.
Thanks I'll see what I can find.
I heard from SESI it seems you need Xcode installed AND the command line utilities installed which can be done from within Xcode's preferences. I am running H12 and Lion.
