Is it possible to extract node presets to an ascii format? (I'm looking for something similar along the lines of hexpand/hcollapse, which does the same for .hip files, or hotl for .otl files).
This would be very useful – it would allow merging of preset files, storing them in a git repo in ascii format, etc.
Any ideas are much appreciated
imre
presets in ascii (or hexpand/hcollapse for presets)
8093 8 2- riviera
- 1708 posts
Imre Tuske
FX Supervisor | Senior FXTD @ Weta FX
qLib -- Houdini asset library
http://qlab.github.io/qLib/ [qlab.github.io]
https://www.facebook.com/qLibHoudini [www.facebook.com]
- grayOlorin
- 1799 posts
- tusimi
- 14 posts
grayOlorin
hey riviera, have you tried saving a preset from the ear menu in the parameter window? this saves an IDX file which is “kinda” of ascii
If not, writing a python node or script that exports a preset as XML is actually pretty simple using python minidom.
Well, the “kinda” ascii won't do – it's the same ‘kinda’ as .hip files, but since I want to put these in a git repository, I'd need them to be full ascii.
Also, since all presets for a node are stored in a single file, it's kinda complicated to merge preset files between users.
- grayOlorin
- 1799 posts
- cklosters
- 224 posts
I used lxml etree for parsing data to xml.
Also because it has a c wrapper that is faster.
Good tutorial: http://lxml.de/tutorial.html [lxml.de]
Senior Technical Artist Guerrilla Games
- pbowmar
- 7046 posts
Yeah IDX files are unfortunate You can use “hidx” to expand them but it looks like there is still uneditable stuff in there
I use “classic” Houdini presets, you need to set an env var first though:
HOUDINI_ENABLE_OLD_PRESETS = 1
This will let you save pure ascii files, though with minimal UI. I have RMB menu scripts though that work around this.
Peter B
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- riviera
- 1708 posts
pbowmar
Not for me, so far – all seems proper ascii. I don't know how I missed this command. Thanks!
imre
Imre Tuske
- rafal
- 1455 posts
I had to look into this recently and remembered this post.
The non-classic presets are stored in an index file (binary) which can be expanded and collapsed to a directory structure with ‘hidx’. The expanded “Permanent Defaults” file contains a mix of ASCII and binary data. Most of it ASCII except for the portion after ‘opspareparmdef’ which is a CPIO packet similar to hip file format.
So to edit anything in that CPIO you will need to convert it to plain text. It's a pain but doable:
- do ‘hotl -x tmpdir mypresets.idx’
- filter or retrieve the portion of the “tmpdir/Permanent Defaults” file starting on the line after ‘opspareparmdef’ and ending before ‘opchannels’ tokens, and save it into a tmp.cpio file
- run ‘hcpio -i < tmp.cpio’ which writes “opspareparmdef” text file
- edit this text file as you wish
- run ‘echo “opspareparmdef” | hcpio -o -O opspareparmdef.new.cpio’
- replace the portion of the “tmp/Permanent Defaults” file between ‘opspareparmdef’ and ‘opchannels’ with the contents of “opspareparmdef.new.cpio” file
- do ‘hotl -c tmpdir mypresets.idx’ to finally arrive at edited presets
Hopefully the next work iteration on presets will make this kind of thing painless.
- pbowmar
- 7046 posts
